Help please, the engine doesn't start. C180, Elegence, 1996
merc77merc
The car doesn't start. It hardly makes any noise when I turn the key. Yesterday after few attempts I can hear the starter turning very slowly. I charged the battery overnight but still no change. The lights are working OK. Is this a battery problem or something in the engine. Thanks
Cole@MBS
www.mbssouthampton.co.uk
Sounds like a battery fault, have you tested the battery voltage??
M
merc77merc
Thanks.
How can I check for the charge? Don't have any instruments.
You need to check the voltage as the engine is trying to crank
M
merc77merc
Thanks.
What would I do if the voltage is low. Can I add water or acid to the battery or it needs changing.
The battery could be past its sell by date, and need to be replaced.
A cheap meter only cost £4
Do check the condition of the engine and battery earth straps
Miffy
Bromley, London
CLK 320 CAB Elegance C208
a timely reminder to beware of trying to jump start your car and making things worse.
ALFIEBEARD
DUMFRIES
JAGUAR XF-R SPORT
Hi turn on the headlights, then try to start the car, do the lights go very dim?, if yes its either a bad connection or the batterys knackered, if they dont dim its probably the starter solenoid or starter brushes/motor.
as above though the proper test would be to measure the battery voltage.;)
hope this helps
Alfie B
M
merc77merc
Thanks everybody.
I will get a meter.
