Help Please....
h_sportline
Sorry if I've posted in the wrong section :(
I have a Mercedes Benz 300CE Sportline (W124) 1992 J Reg. Last year on the way up north I got cought in abit of traffic, it was a very hot day. My engine started to heat up but I then turned on the hot air which cooled it down. From then I got the car serviced and everything went well till now. The car has been heating up alot and theres a leak in the radiatior. Can anyone help me as I don't know if its the radiatior itself causing this problem or somthing else :confused:
Could anyone help me please?? also I'm looking for a radiatior the cheapest I found was on eurocarparts which was £120. The car hasnt got air con.
Many Thanks To All That Help :)
H
Don't forget that 85c is the min normal temp for any car, re the rad leak do you know where it is leaking.
malcolm
H
h_sportline
I tried this stuff thats suppose to stop leaks but it didnt work so it looks like I've got to change that aswell :(
I think it might be the fan clutch which isnt working properly.
Does anyone know where I could get a cheap radiatior as said cheapest I found was on eurocarparts which was £120
Can anyone help with the high temp prob I'm having I'm still confused :-(
H
h_sportline
Found the problem guys :D
It was one of the pumps that wasnt working. I took the connection off cleaned it and put it back on and it works :D I also changed the water cap.
Many Thanks to all that helped me :D
H
H
h_sportline
The pump that wasnt working was the electric water recirculating pump, I've also replaced the fan. Everythings ok now :-D
Many Thanks Everyone
H
