Help please
Szade79
New Registration
C220 cdi
Hi all I have just bought and fitted a new battery for my c220 CD and it worked fine for 5 days but I went to start my car and it was totally flat, I have tried jump starting it it tries to start but as soon as u disconnect the jump leads there is absolutely no power there again any ideas
Tia
Tony Dyson
God's Country
2014 C 220 CDI W204 OM 651
Check your alternator is outputting a charge voltage of between >13v <14.8v
DREAMER NO2
W124 2.6E M103 1989
Your battery is flat again so first step is to recharge the battery . Over night it will go flat if regulator is no good .. Could be that the alternator will just need a new regulator . But as above post from Tony get a check on output from the alternator first. Also is the battery light on before you start the engine ? and going off after it starts . Also both of the posts on the battery must be making a good contact ,remove and clean them up grease each one and replace it . And i dont like jump starting any car ,,you can cause problems for yourself .
Regulator failing can flatten a battery overnight
