Help Rear windows don’t work
Spud990
E300 TD 1998 om606
Hi I have got a w210 E300 estate the rear windows don’t work I have tested the motors and changed the switch’s but still no joy can any one help?
Paul Sander
Surrey
2003 SL600
Do they not work individually from each door as well as from the drivers main panel..?
Spud990
E300 TD 1998 om606
Don’t work at all but the front windows do.
brandwooddixon
Wolverhampton
S63 Coupe 2014
So to be clear, the rear windows they don't work even when using the switches in the front of the car?
You don't have child locks activated on the window (little switch down between the drivers side switches)?
badger_wazzala
The United Kingdom
63 AMG
Do you know how to test the switches for continuity using a multimeter?
You could apply power via a fused lead direct to the motor/window regulator (taken out of the door) to see if it will indeed turn and hasn’t seized.
Starting point would be to establish if power is present at the switch. If it isn’t test continuity of harness by disconnecting both ends and using a multimeter.
I’m happy to advise step by step if need be.
star
Reading
Smart + others :)
A faulty can can do this, even if a motor is working, it can disrupt the other signals.
ajlsl600
france
Likely something that controls Both sides as doubt both sides have wiring issue. Op seems to say both rear not functioning, check fuses, maybe fault in one side rear blow fuse that does both sides?
star
Reading
Smart + others :)
I’ve seen this before, try disconnecting one window motor at a time and then trying rear windows, as said even the fronts that work can stop the tears from working.
Spud990
E300 TD 1998 om606
Hi everyone thank you for your help. There is power at the windows I have pulled out the motors and checked they are not seized. The child lock isn’t on. I have tried a different main panel up front. Still don’t work. Would it be something to do with the modules?
ajlsl600
france
Looking that way..but I would be trying everything 2,3x before parting for any replacement module. Have you checked any fault codes that might be related.
Spud990
E300 TD 1998 om606
No fault codes present. Dose anyone know where the module is?
