Hi, Can any of you guys or gals let me know what additional parts I will require to enable me to fit Comand to my W220.
All I have is the comand 2.5 unit and the wooden facia panel. I have removed the standard audio 10 and the feed/earth and speaker plugs seem the same but it leaves me with a few connections on the rear of the comand for which I have no explanation for.
I have connected to feed/earth and speaker plugs but the unit wont even power up do I need the unit coded to the car before this will operate.
I know I will need a gps aerial but the local dealer say there are to many variations for them to select correctly.
I am ok with the connections I have marked with a green dot (live/earth, speakers, cd changer, fibre optic connector and radio aerial) but I am clueless regarding the ones marked with a red dot ( small multi pin connectors above live/earth, small gold connector at side of radio aerial, small connector below a blue rotating switch, large multi plug connector located on the lower middle of the unit and a slotted connector just under it.
Also there doesnt seem to be any way of mounting the comand in the dash, do I need a seperate bracket or any other parts ?
I would appreciate any help or even a contact who can complete the install for me - I am located in South Lanarkshire.
dont know if this picture will work but I'll give it a go.
