Help!! SLK Headlights
jezzyper
I've seen loads of posts on this subject but nothing about an R171 SLK200.
I am going to France and need to find out where or how to adjust the headlights to dip the beam the right way.
Thanks for your help.
Halogen or Xenon and first 6 VIN numbers
Malcolm
Hi & Welcome,
Firstly do you have xenons or halogens?
snap - my excuse is that I was on the phone answering a political survey.
jezzyper
More info...
Sorry, Bi xenons. VIN (6 digits): WDB171
Thanks in advance
Should be a switch in the back of the lights then
jezzyper
Have checked behind lights again, and located black plastic wheel with teeth around the outside which it appears can be rotated - could this be the way to adjust the dip? All other posts suggest that it would be a yellow lever?
I will post back later tonight
malcolm
45360
New Forest Uk
slk 250cdi amg 2013
this has nothing to do with lights but to do with you going on a long drive....
my SLK 350 from Nov 04, recently I asked my Merc dealer if they could fit a connection to the AUX input on the car audio system so I could use my iPod, but was told that it wound be much too expensive, fast forward 3 month... changing cd in the changer noticed a small hole on the left side of the glove compartment, pushed a 3,5mm jack plug into it and the other end to my iPod h/ph outlet, pressed the Aux btn. and bingo Ipod through the audio system, quality a good as cd.....is this a well know fact, am I the last to find out?
This is mentioned in the hand books but not many people read them.
malcolm
After a long search (1 hour) I have found the paper, the 171 is not on the list
the 203, 209, 230, 211, 215, 220. are shown
from what i can work out coded lamps 614 and 615 are adjustable.
Sorry cant be of more help.
Malcolm
