hi i am a mecanic but i am a bit stuck on this one.
it is a ml270 i think it is 2000 not to sure its on private plate.
it starts then dies and wont go untill you crank it over about 5 times and is fine till you leave it for a while then it does the same
i have code read it and i got so many codes i really dont want to type them all in but i dont know when it was last cleared so they could be old ones the only thing coming up is p0008 which just reads mecanical problem there also is one pending code which is p000c which is very wierd.
has any one come across this if not i guess i am going to be very busy at work.
cheers
cheers
