Help! W210 headlamp washer wiring
youngblood
USA
E430/98/V8
Does anyone have instructions for installing the wiring harness for the headlamp washer to the fuse box and dashboard switch? I have this diagram but I don't know exactly where everything goes. Does anyone know where these need to connect? If so, please let me know. Thank you in advance for your assistance. If you have any more diagrams and pictures, they will help also. Thank you in advance for your assistance.
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
Malc, the link you put up is for the 124, not a 210.
I have the WIS retro fit instructions for this loom, youngblood if you drop me an e-mail I will reply attached the document.
The link that I put up covers most cars for the dates given and all the 210 wiring is in that link
Naraic
2005 CL500.
When you put in 1996 or 1997...no list is shown. The diagrams for 1995 are indeed for the 124...they show wiper motors for the headlamps...which the 210 doesn't have.
bigasotonuk
Southampton UK
For goodness sake in the link that I put up you just go to the top left,chose the year, then the car,next diagrams and its all there, as I said it cover most cars.
I just defaults to the one that it opens with on my system
Naraic
2005 CL500.
When I put 96 in it doesn't produce a link.
What it does produce is a list for most,,, if the specific car is not there, say your car is a 200 if there is not a 200 diagram for 99% of the diagrams they are the same as say a 220 or any other model in the range. the only difference between most is just the engine ecu.
This is the only link on line that I know of where any such diagrams are available, and again just for instance the heater shall we say is the same across all the models.
The whole point is even in WIS the program does not start on your car, you have to find it.
Next time I put the link up I will say "find your car top left"
Y
youngblood
USA
E430/98/V8
Hi bigasotonuk,
My email address is stunnanumbaone@hotmail.com I have already purchased: washer bottle, washer nozzles, washer cover, switch, wiring loom. Do you know if I need anything else? Control module unit maybe? Thank you in advance for your assistance.
Y
youngblood
USA
E430/98/V8
Thanks Naraic.
I still do not see on the diagram where the solid red cable connect to. I see the brown/blue and red/grey go to the pulse module. Can you or someone tell me exactly where these 2 solid red wires go from this picture? Also can someone tell me where the pulse control module are located from the diagram? Thank you in advance for your support.
