Help!! What are these codes for?
Quaver
W212 E350 2010
Hi guys so got 4 codes coming up on my Carly adapter but has no explanation so just need u guys to shed some light on this.
Following codes are
00FF14
0000EC
00A700
0013AF
Under the categories "Motor electronics"
mikestrivens
Stockport
what fault are you trying to diagnose? Probably needs to be put on a STAR system at Mercedes or an indie.
Quaver
Quaver
W212 E350 2010
I'm not experiencing any particular fault just EML is on and Carly doesn't want to clear it
Quaver
Quaver
W212 E350 2010
They don't look like any recognisable code I've seen before. Probably best to ask Carly or get it read on a STAR.
Craiglxviii
Cambs UK
I’d forget Carly and go with something that can read actual MB codes...
Quaver
Quaver
W212 E350 2010
So I took it back to terry and had it put on star and only 3 codes came up and they were all to do with dpf. But the thing is my dpf has been removed. I assume it has something to do with dpf pressure sensor as there was some rewiring done with this at the time. so will get this replaced and see what happens. Does anyone know if I leave dpf pressure sensor unplugged will it do any damage to anything? EML has been cleared now for now anyway so will see how it goes
turbopete
Spennymoor
if you have removed the DPF, good luck getting it through the new MOT regulations when they come out. ANY visible smoke from a car that should have a DPF will be an automatic fail when the new rules come in. that's the reason I didn't have mine removed and remapped.
this isn't the original article I saw, but it basically says the same thing.
http://garagewire.co.uk/news/mot-dpf-changes-now-expected-in-may-2018-dvsa-confirms/
Jim2
I am trying to piece together the service History of the w212 I bought in January and while in the local MB dealership I got this printout from the service department and it was generated from the VIN.
So speaking of codes..................
Under the heading Damage Code:- 059902367
and under Damage Code Description:-1204P59A93. ( both these Nrs are on the same line on the sheet )
and these code's refer to the same item, and give a Claim Nr 2275200.
Any ideas as to what these Codes actually mean?
Also on the same sheet: Damage Code Description ( without the Damage Code Nr.):- Service Major-WNH. Carried out at 51436 Klms.This one is self explanatory, except for the WNH bit.
Thanks, and Best Regards, Jim2
