**HELP** White car lower part of the car
Wolfy95
C250 CDI AMG 2015
Hello guys, I have washed and decontaminated my car. I've applied bilt hamburg surfex hd to the lower third of the car then snow foam over so has more power to cut through the lower half. I've then contact washed the car. Then used tar and glue remover on the lower third of the car. Then used fall out remover lower third of car. Some of the spots went with a damp cloth I had wiped over. I don't want to clay bar yet as I'm not sure it will ruin the lower part. My issue is I can't go any further with the lower third of the car because there is literally **** on there that you can still feel with your hand afterwards. Please help me its a white C250 and I can't continue to polish, Wax etc as the paint needs work. Ive tried everything but I don't want to ruin the paint its so stubborn whatever it is.I Will post a photo tomorrow as it's rained here and needs a wash again.
Wolfy95
Wolfy95
C250 CDI AMG 2015
AMGeed
Poole, Dorset
1998/2001 W210 E280 x2 SOLD 2004 W211 E55 SOLD, 2014 E63 Biturbo SOLD .S204 C180K
Use a Meguiars clay mitt from Halfords. Very effective and easy to use with a lubricant.
WD40 if it’s tar
Wolfy95
Wolfy95
C250 CDI AMG 2015
Wolfy95
Wolfy95
C250 CDI AMG 2015
Mr Greedy
Leicestershire
E350/2011/OM642 265bhp
I find if there is particulate stuck in tar, it requires a few repeat attempts of glue and tar remover, then fallout remover, then GTR again, then fallout remover again. This is especially prevalent on wheels. The first bit of tar is removed, exposing some brake disc material, which is then removed with fallout remover, allowing you to get the GTR back on to the tar, which exposes some more metal.
On particularly bad wheels, I've literally needed 10 or 12 applications to shift the worst bits via contactless method.
The other option is clay bar and then get to work with the polishing once contaminate free.
rorywquin
North Yorkshire
An old B-Class.
I've removed most of it with the tar remover but whatever it is it won't budge.
Once you are rid of teh tar etc Use a iron remover before claying. Carpro do one (e.g. as in the link but there are others) .
morgluis
2016 GLA 250 2.0
Any pics? This will help others to provide better recommendations.
JBell
Torquey
C350 CDi Estate (GAD Edition)
