dannyfiveforty
- Jul 30, 2008
- Location
- Staffordshire
- R230 SL500 2003
good evening all,
I have a problem with my Aircon and don’t know what route to go next.
Car (2008 CL63) had ‘aircon off’ permanently lit and fault code of low refridgerant pressure.
I have increased the pressure by adding gas using stp refill kit. Pressure is up to 30psi (on the low pressure side) I have now removed the fault code and the car now recognises the gas pressure is there and it is letting me now have ‘aircon on’. After a 10 mile drive the aircon is still blowing warm air, and I have gained a hissing noise that sounds like it is just behind the centre console vents. I have checked for further codes and nothing except for ‘94DD m16/33 left B pillar air distribution actuator motor communication error’ this confused me as my car doesn’t even have b pillars.. anyway, that aside, as I don’t believe that would cause aircon to blow warm.
Using my live data machine with the engine running I have engaged and disengaged the compressor several times whilst listening to it, it has a tiny jolt and belt noise variation as it loads up when coming on and off, plus it’s giving no codes. So I believe that’s running as it should. Finally after 24 hours I have re checked the aircon pressure and it’s holding exactly the same pressure as I put in.
So what’s going on?
So what’s going on?
