Jose Collado
- Dec 5, 2005
HELP with bleeding brake system 190E 1993 (without ASR) I went to bleed the brake system, and found myself in the middle of something which has caused many hours of frustration.. From the rear brakes, only the brake fluid which was in the pistons came out, after that not one drop, in spite of using both the brake pedal and the vacuum pump methods. The level of brake fluid in the reservoir does not decrease, nor are there leaks in the system.. (The front brakes bleed well.) Does anyone have an idea as to what is the problem?/
