Its Golf as in VW and not a good walk spoilt. Ok sorry its not Mercedes, but it is German and is owned by the future Mrs Slinky were I daft enough to ever ask. (Which I am not by the way, so lets just say were good friends eh?)
Anyhow, maybes people on hear can help so here goes.
a 2ltr petrol Golf Mk 4 (04) 5dr. And yes, its Primer!
We have developed a squeaking which appears to come from the offside rear. Its very noticable from outside, but sounds from the inside as a kind of wheelbarrow squeak if you can imagine what I mean.
Annoyingly it seems to be intermitant and doesnt make the noise on command. You cannot replicate the noise by driving style, such as leaving the handbrake off and coasting downhill, or by pulling away with right or left lock on. It doesn't always occur, even when wet or after washing, and will make this noise after a considerable journey when really warm, and can often make the same noise after being stood overnight either outside or when its comes out of the garage. it does seem that it doesn't make this noise at speeds above 3rd gear if you see what i mean, altho that may in part be due to the noise being overcome by road, wind and tyre noise but lets says its noticiable at low speeds.
If you were stood on the pavement you can quite clearly hear this noise as the car goes past, when it makes it.
Lowering the windows on the both sides suggests its coming from the offiside rear and is definatley and exterior noise which is loud enough to be heard inside the cabin. When its been to the dealer, and this has been mentioned, of course it didnt do it with them, and when we have taken them for a spin, it refuses to play up until we have gone our own way.
Am still searching the net for information, and a few friends have had the same, or similar noises, which appears to be cured with new brake linings, pads etc, this car has rear disks, but after a few months or so, they get the noise back. All golfs mk4's but not 2ltrs.
Is it just rear brake pad wear? can it be, and this is what I think, a sticking caliper or could it be something like the handbrake cable, suspension arms or something mechy like that rubbing another bit? Does it appear to be the start of something which could eventually get more serious? and therefore need sorting, or could it be the anti squealy bits not doing their job or the anti squeal grease wearing off? or something simple and not to worry about as such.
it sounds on both left and right turns.
Anybody any ideas that may help shed some light on this and what a possible cause, cure is?
I realise you cannot diagnose from a description so I have tried to fill in as many blanks that can be, in the hope that someone can either recognise the fault through experince, or offer all possible causes and how to test for them, so we can eventually eliminate them which, by Sherlocks deductive powers, leave the one remeaning, no matter how elementary, clue as the culprit!
Have asked this on a VW forum too, and maybe the odd MB forum too, so any info I get I will post up here if it offers help to anyone with the same or similar problems in the future.
