help with my Sanity. Trim Query on 1997 SLK
Status
Not open for further replies.
m14cey
I have a very simple question but its not that simple to describe so bare with me.
If you sit in the drivers seat down to the right you have the furry door seal. Put your hand on the door seal and follow it backwards until it ends.
When it ends you will see a metal plate with three screws in it. As you look at the metal plate, face on, there are three screws, one on the left and two on the right.
If you remove the plate you will see that the screws go into some white plastic lugs, located into the body work, which have a cone shaped rear.
The query.
Do the screws that hold the plate on also hold in place a black piece of trim, or does the trim locate at the back of the white cones behind the metal body work.
see told you it was difficult to explain.
If anyone out there has 2 minutes and can take off the metal plate, i would really appreciate it.
Or perhaps drop me a mail with a number and I'll call you.
Sorry to be a pain in the ass, but this is driving me absolutely bonkers.
Cheers
Mark
Tel 07970089762
Matty H
I will have a look for you, but don't have my car with me today. If you can wait till Saturday I can let you know then. Hope this helps?
Matt.
M
m14cey
Thanks Matty, I would really appreciate it.
Perhaps the easiest way would be to let me call you when you are with your car, or if you remove that metal plate, and text me a photo of what it looks like underneath i will be able to work it out.
I took the back carpet and plastics off last night to see if there was a cut out for a base speaker and just cant seem to get this bit to fit right.
Ive also got an amp in the car somewhere but im buggered if i can find it.
cheers
Mark
M
m14cey
Matty,
Thnaks for the offer of help but sorted problem.
When down to the dealer, found slk open, in there with screw driver, mission accomplished.
Cheers
Mark
Status
