help with panel lights
Status
Not open for further replies.
e220man
uk,oxford
heater control lights not working ,,, how do u get to them???,, taken out centre consol but cant seem to manage to get upper wood dash out, do i have to take out cd player to get to the bulbs???,im sure the bulbs r loose as it goes on and of at random, was ok until i had sounds fitted last week..
cheers....E220man.... "95" e220
Spike
London
1999 SL500
Directly above the stereo (facing up) you will find there are two small screws holding the bottom of the panel in place. The upper part is held in place by two large nuts hidden behind the two main dials (which just pull off). Once done the wood trim will lift off.
NormanB
Portsmouth UK
E220man
Not particularly familiar with this modern metal!
If you are talking illumination for fan speed and circulation control (Knobs) then once you pull these off the bulbs are sitting in the end of the spindles.
If you are talking temp control (Wheels/Dials) then you will need to proceed as advised by Spike - once you get the wood off it is fairly obvious what you have to do - if its like mine then you will need at least 4 bulbs (2 knobs, 2 dials) - get them from the dealer before you start the job ( and a couple of spare ones for luck!)
NormanB
steveb
Centre air vent bulbs
Does anyone know how to get at the centre air vent bulbs?
Steve
steveb
Not to worry - I found well hidden behind switch panel .
It helped looking at night!
Steve
Status
