benzfanatik
- Jun 4, 2005
Hey all,
My 1995 W124 E320 has recently been giving me problems with hesitation and studdering. Sometimes, when I am at a stoplight, the car will bog down (500 RPM) for a split second and come right back up. Also, when I am accelerating, when the tach hits about 2200 RPM, it starts to hesitatae and will not go any higher, even with the pedal to the floor. If I let off a bit and give it more gas, it does fine. As soon as it gets to about 2500 RPM, it takes off like a champ. Also, I was tinkering around trying to figure out what the problem was and I noticed that if I rev the engine either in park or neutral, it acts as if it has a rev limiter at around 4500 RPM. It will get up to 4500, and bounce around between the 4500 and 4700. If I am driving and hit the gas, it goes past 4500 RPM no problem. The check engine light was on and I took it in, and the mechanic cleaned the EGR valve, which shut the light off but didn't fix the problem. Any suggestions or comments would be great! Thanks in advance
