Hi all new to site with battery drain issue
Paul hayes
Merc des 320 cdi 2003
Hi new to forum my Mercedes 2003 320cdi drains battery in 30mins
Have disconnect all fuses form all fuse boxes and relay
Removed all bulbs but still battery go flat can any one help
Hello and welcome
Moved out into a new thread for you
AMGeed
Poole, Dorset
S204 C180K
Where are you located?
It would be best to get the car to an independent Mercedes specialist (indy) who has the correct diagnostic equpment (STAR) to pinpoint the problem. The labour rates at an indy are less than half of main dealer rates and I'd trust one to find the fault quicker too.
P
Paul hayes
Hi west London
P
Paul hayes
Hi biobcat
Snap tit out !
Do these engines have a block heater?
That's the usual cause of a bad drain if the battery is good.
W210 did, switch in the ash tray on my yr2000. Later ones were automatic below 5’C
Flyinspanner
Ruislip
There can be many causes.
How are you with working on this yourself?
You’ll need a clamp meter.
Place clamp over battery cable, look at drain reading, and I imagine it to be high.
Pull fuses one by one until the drain disappears - you’ve then found the system with the drain. - you then have to decide how to fix that system.
Could be wiring, could be a component?
Headunits sometimes don’t shut down, but to drain a good battery in 30 mins it would have to be a really big drain, something would be getting pretty hot.
How old is the battery? Is it a good make? Have you had it load tested?
I had a battery fail internally/intermittently after 9 months, presenting just as yours. I spent hours chasing the drain.....
Changed the battery and all issues disappeared immediately.
EUrocarparts often have discount codes online to save 30-60% on batteries, it may be money well spent to rule out failing battery before you spend hours chasing down a fault or worse £££ at a garage getting them to try to diagnose.
Regulator packs breaking down can cause an intermittent drain as it depends on where the alternator stops as to if it drains or not. Had that on a 911.
P
Paul hayes
Hi many thanks will buy a clamp meter
I have pulled all fuses one at a time
I have disconnected alternater and starter motor
Make sure when you buy a clamp meter you get a DC one. Most cheaper ones are AC only (and won't help).
Flyinspanner
Ruislip
I think a drain of 60mA is OK after 10 mins.
(It takes some time for the car to ‘shut down’ after keys out.)
Remove boot interior bulbs or ensure switch is kept pressed.
If you removed all fuses, (front and rear?) is the alternator warm? =diode pack. And have you had battery load tested - Halfords will check for free.
P
Paul hayes
Hi just fitted new battery flat in 1.5 hrs alternator disconnected starter motor disconnected
Not much left, what model is your car?
W210 320 CDI has an fuel powered heater booster.
W211 320 CDI has a PTC element in the dash that could flatten a battery in less than 2 hours.
Flyinspanner
Ruislip
Battery control module? (Don’t know if your model has one?)
Some models have more than one ‘fuse box’ - check them for corrosion.
It’s a massive drain to flatten in 1.5hrs....
Are there any electrical items that don’t work/blow fuse when switched on?
Have you tried with clamp meter, pulling fuses one by one until you see the current drop?
Are the battery cables pinched/chaffed?
