Hi All
Tyre kicker Gary
2018 W213 E220D AMG
I'm new to the group, have a lovely E220D AMG 40K on the clock and I've joined you guys to try and get some clarity on an issue that I have with it.
I get a constant clunk when it brakes to a stop, then the same clunk when I let the brakes off to move. Sadly, it also does it fairly often just bouncing over potholes or lumps & bumps.
At first I thought it was suspension based, but today, I jacked it up and played turn the wheel and have noticed a good old clunk when I turned the propshaft & held the disc. I can get about 1/3rd of a turn on the propshaft with a clunk at each "stop" I then held the propshaft still and turned the disc, still clunking.
My assumption is... this means worn driveshaft bearings, coz if it was propshaft bearings then it wouldn't clunk when I only span the wheels.
Also, is this it? I don't see how this would clunk going over lumps & bumps, but definitely can see it on stop/starts.
Anybody got any ideas, I don't want to spend £500 on replacing driveshafts if its some suspension bushes.
Help please. - I have a great video of this but its 12mb and so is too large to upload!
thanks in advance for any good ideas
cheers
Gary
Hello and welcome
00slk
Cambridgeshire UK
Hello and welcome
SmartAmg
2011 E class coupe 350 CDI
mioba
Nottingham and Köln
Welcome to the forum. enjoy the bumpy ride. you will get there
harrye500
Cheshire
2010 A207 E500 (the Summer Car and Winter Garage Queen)!
Could possibly be suspension or Ball Joints but the play in your propshaft is certainly suspect. As Dry Run - find a good independent for a proper diagnosis. My thought is prop but diagnose first rather than chucking £ at it and not getting a fix. Certainly it can clunk over bumps as the car negotiates them.
Paul Garrett
Hi and warm welcome to our forum, I hope you get your issue resolved ok?
T
Tyre kicker Gary
2018 W213 E220D AMG
Thanks all
I have found what looks like a decent Indy, he's ruled out the propshaft, it's what he says is acceptable backlash.
He reckons suspension bush or ball joint, so it's going in next week for a coat of looking at.
I will report back with what he finds
Cheers.
Scholsa
2012 W204 C180 Estate AMG Sport
Thanks all
Cheers.
How did you get on?
T
Tyre kicker Gary
2018 W213 E220D AMG
Hi All, well, he's a great indie, very thorough. Main issue is front upper wishbone ball joint. 3mm of vertical play. Replacement part is £80.00 which I consider reasonable for the entire wishbone. There's also a small amount of play in the rack to tracking arm joint, so I'm getting that replaced whilst it's in.
FYI indie is Martin - MPH Autos in Buglawton, Congleton.
