Hi I have a CL500 my name is Dave
Done rear valve block but the front stays to high any help please
  • Done rear valve block CL500 the front stays to high
    Votes: 0 0.0%
  • Rear valve block
    Votes: 0 0.0%
  • Total voters
heer123
CL500 2003
Done rear valve block CL500 the front stays to high can somebody help please
Hi and welcome. Have you set the heights on Star?
H
heer123
CL500 2003
Yes but driver side don’t go up or down when you press the button in side
A.J.
Norwich. UK
Hi and welcome to the forum :)
SmartAmg
2011 E class coupe 350 CDI
Welcome, Dave. :D
Craiglxviii
Cambs UK
Sounds like a gunked up front valve block to me.
Dave/ Heer, what type of o-ring material are you using for replacements?
H
heer123
CL500 2003
X8r seals no errors is it worth trying to bleed from nipples
As Craig it sounds like you have a problem with the front valve block.
Craiglxviii
Cambs UK
If they’re not aerospace grade Viton coated then please rest assured, you will have problems down the line. Take it from someone with painful experience of 50+ valve block rebuilds over the last 6 years!
Craiglxviii
Cambs UK
Specifically, shuttle valves in the front valve block... but if one is jammed, the other 3 will follow suit.
Plus, as another thought, a fluid flush and filter change will be needed after all this work...
H
heer123
CL500 2003
Thanks mate I’ll check the front valve block & do a rodeo what’s the sign when the accumaltor goes & it was fine before it only happened when I done the rear valve block could it have air lock
Accumulator failure depends on which one (there are 4).
The two for each axle will post an error in the dash in a large bump which then goes away.
The pulsation damper makes the system whine if it fails.
www.ckinsurance.co.uk
