CLC is based in the C class chassisNot sure he says c class not CLC but I'll check. Thanks.
So all basically the same. I thought as much. I had a misfire on cylinder one, changed spark plugs( which turned out fine) swapped one and two coil packs. It hasn't done it since, about three weeks now. So thinking it might be dirty fuel, hence going to change fuel filter.CLC is based in the C class chassis
