High level brake light C180
XJ Nick
Hi can anyone help?
I have an 1998 C180 saloon auto.
The high level brake light has started to flash on and off when the brake pedal is pressed, the other brake lights are fine. I stopped the car for afew hours and it was ok for a minute or so then back flashing again.
Any help would be most welcome.
Cheers Nick.
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
did you check cables that none are split/rusting ? check the bulbs that the contacts are clean and corrosion free ?
X
XJ Nick
Hi Anyweb
Yes I looked at all that. The whole thing has stopped working alltogether, I think it may be the unit that has packed in. I will try giving it a good clean and see what that does.
Cheers Nick
X
XJ Nick
No luck I will see if a new unit does the trick.
Thanks for your help
Could you not just connect it directly to the or a battery and see if it lights up
X
XJ Nick
Hi Malcolm
Never thought of that. Thanks will give it a try at the weekend.
Cheers Nick.
X
XJ Nick
Hi Malcolm
Gave that a try, does not work. It must be the LED unit. Will price a new one, or may go for an after market one.
Thanks for all your help.
Cheers Nick.
If it is LED then it is polarity conscious when you test
X
XJ Nick
Hi Malcolm
Sorry I took so long to get back to you, my computer is playing up. I tried both ways to no avail.
Thanks again Nick
Hi Malcolm
Thanks again Nick
If you can get it to pieces then it is possible to replace the faulty LED
X
XJ Nick
Hi Malcolm
I still have not priced a new one. I can get it to pieces, will let you know what happens next.
Cheers Nick
Hi Malcolm
Cheers Nick
These things are just LEDs in series and groups may a resistor as well
