Hi all, I wonder if someone can help...
The close assist on my boot doesn't work (SL500 04). It does the usual thing of working for a while after I pull and replace the fuse under the rear storage compartment, but then failing again. I checked the vacuum to the rear lock and it seemed ok, I even had the lock pump changed (was done under warranty) but that was ok too. Then tonight I heard a hissing from the driver seat and thought maybe I have a leak there. When I looked under the seat, I found a length of rubber pipe (about 18") that was connected to a vertical nipple under the lumbar adjustment control, but un-attached at the other end. I've tried in vain to find where the other end of the pipe should attach but to no avail.
Could anyone give me a clue as to where it should go? And do you think that is the cause of my close assist failing as I believe the two are connected?
Thanks in advance.
Thanks in advance.
