Hollow clonking
Larchlap
Attleborough, Norfolk.
Hi all, I have a 2002 C180, there seems to be a hollow clonking noise from the nearside front wheel area when you go over drains / road imperfections, I had the same sort of noise when I had a Mitsi FTO and it was the front droplinks, does this car have droplinks? The Chassis number starts C203 any help / idea's would be good.. Thanks. larchlap. :confused:
ernieh
Scotland, East
Hollow Clonkings
Hi Larchlap,
I also have had a similar problem with my 54 plate C200 for the last 18 months or so, the car having been at the dealer's for diagnosis and repair several times. The car was in there again today and they have ordered a new n/s/f strut, although they are also going to adjust the wheel bearings.
Don't ask me how they tested the strut, however, as it felt OK with just a knock present at slow speeds when going over drain covers or speed humps.
The car goes in on Friday, so will let you know the outcome.
Regards,
Ernie
khfcfan
I've got a similar problem with my W210 E280.
I've changed the bottom ball joints and anti-roll bar bushes and tightened the wheel bearings, although it is better it still isn't quite right, so next on the list are the stabiliser arms this weekend.
C220GJS
Shotts, Scotland.
1995 W202 C220 Elegance
This is your front anti-rollbar Larchlap;http://www.detali.ru/cat/oem_mb2.as...623716.634&CT=F&cat=69J&SID=32&SGR=060&SGN=02 ;as you can see you do have droplinks.
Ellsy Tanners
Mars
Drop links are the most common cause as the guys have said.
When they are baddly worn you can feel the play by firmly lifting the anti roll bar up and down! check this first
Larchlap
Larchlap
Many thanks for all the input from you guys, the car is due for a service soon I will get them to check the droplinks.. Thanks.. larchlap.
P.S. I would do it myself but I am recovering from bowel cancer so I am at the mercy of a local indie..
ernieh
Scotland, East
Clonkings
Just to follow up the earlier post.......Replacing the n/s/f strut seems to have cured my problem, although my local local Service Advisor says that they don't normally have problems with struts on these cars even after high mileages. More commonly the problems are with the droplinks and that mainly on the pre-facelift models, after which the seals were modified. For info, during the last 18 months or so, my strut top bearing has been replaced twice and the lower wishbone once. Glad I didn't have to pay for that lot!
Sorry to hear about your health problems, Larchlap, trust you will soon feel stronger and better able to 'do-it-yourself'.
Regards,
Ernie
Larchlap
Larchlap
Hi Ernieh, just an update on the suspension problems, I have been able to change the drop links and the anti-roll bar bushes myself, problem solved, now nice and quite.. Many thanks for everyone's input. larchlap.
