Horn contacts on a SL350
Steve the horn contacts are in 2 parts, the switch built into the air bag and the clock spring on the steering column.
You can unsrcew the air bag by removing the 2 x 28mm torx screws on the rear,you do need a 2" long bit to do this, do not unplug it but turn on and see if the contact is suspect in the air bag unit, by holding the back plate and pressing the horn. if OK then turn the steering wheel a little to or shake the wheel to see if you can set it off, also tap the center or wheel quite hard while holding the air bag.
The chances are that it is the clock spring that has gone and fairly easy to replace and I can give you the instructions.
Do not unplug the air bag while the ign is turned on, or it will record a fault
Hi Malcolm,
Pls let me know which thread this should be part of and I will nail them together.
Hi Malcolm,
It is for a member of another forum, and I would like him to join here as we can give much better advice than they can on a 230, I have helped him before.
Hope that this is OK Blobcat
The original fault was that the horn blew when going round corners and when parking
OK, No problem, I cannot attach to a different forum... however I will move it into the Electrics section
Now in this forum (see many familiar names!:D)
and thanks for the advice;)
I can post you any help you need as I have your E mail address and you need a few post before you can PM, its nice to see you here :D:D and many from there here as well
colechelle
Resigned
just to but in, there is a mod kit for that fault, got one in the van, the basic bit is the screws a a couple of mm longer giving the contacts more distance!!!!
Thank you very much for that,,he is a good friend of mine and I have E mailed him the news
colechelle
Resigned
will put the part number up tomorrow! and yes to your pm tonight, course i will!!!!
Cole,,your mail box is full
