horrendous noise.
teddybear581
SLK55 AMG 2013 R172 5.5 V8
My 2013 SLK55 AMG V8 suddenly developed a dreadful noise. Only when hot. no smoke, no oil leaks no problems with driving. I obviously don't want to drive until I know what it is. Any suggestions while waiting for the dealer to get back to me. Caught the noise on my ring doorbell which is attached as a zip file.
  • RingVideo_20211126_232946 merc.zip
mioba
Nottingham and Köln
No idea. but if your car was last serviced at MB you will have mobilo. give them a call
00slk
Cambridgeshire UK
Sounds like an idler bearing or the supercharger bearing?
SL63 Mark
The South
R231 SL63 AMG
I don't the SLK '55 has a supercharger, you need a SL55 for that.
Could be wrong (and often am).
T
teddybear581
The SLK55 is normally aspirated so no supercharger. The garage say it a diaphragm in the oil separator pump.
The SLK55 (R172) has a relatively rare M152 engine - V8 normally aspirated of 5.5 ltr capacity - only used from 2012-2016
It is derived from the M157 (5.5ltr twin turbo) which is derived from the M278 engine which is 4.7 ltr capacity and twin turbo charged
00slk
Cambridgeshire UK
SL63 Mark
The South
R231 SL63 AMG
Yep, I am wrong again :rolleyes:
Shame really, the SLK would have been pretty quick with the kompressor engine.
Back on topic, the noise sounds like ancillary belt pulleys bearings/alternator, water pump, power steering etc. etc. Does it sound like it's coming from the front of the engine ?
T
teddybear581
It does sound like its comming from the front but its difficult to pin down exactly where.
Brian23
EClass
Get a Mechanic's Stethoscope. They are great for this and not normally expensive. Often available at local parts Specialist, Halfords etc.
00slk
Cambridgeshire UK
So would have the R170 with a 5.5 supercharged SL engine :cool:
Take off the serpentine belt and briefly spin up the engine.
If no noise spin each bearing by hand. If one is gritty or anything other than smooth feeling you have your answer.
