Hot air cold air....
Kully E220 Coupe
Hi Everyone,
I got a bit of a problem at times i am only getting hot air from my driver side vent, the passenger side vent blows cold air even if i select it to blow out hot air??? after a while (20 mins) it starts with the hot air? any ideas what is wrong with the hetaing system?
Any help will be much appreciated.
Regards,
Kuldip
C220GJS
Shotts, Scotland.
1995 W202 C220 Elegance
Do a search for "duovalve",it's the electronic solenoid valve unit which controls the flow of hot water from the engine through the heating system and may be sticking.
Geo.
K
Kully E220 Coupe
Geo.
Cheers Geo i done the search and its proving very helpful i will check out the duo valve 2mrw hopefully it s jus a case of a fuse blown, can i also add taht the centre console has also been replaced in the car could someone have forgotten to connect everything correctly???
kully
