Hot Air only
garyj144
slk r172 2014 C250cdi
Evening folks. My recently acquired 2014 SLK R172 only seems to be blowing extremely hot air from the climate control system regardless of the temp setting on the dial. Any help would be appreciated. Many thanks
mattkh
England
A160 W168 1999 1.6
As in a CH boiler, have you tried turning the temp setting dial all the way to zero then back up to the required temp..
John77
E200 Estate 2011, 2009 SLK 200
If it is like my Eclass there is a valve that lets the hot water through and can stick. The heater valve control is in the engine compartment, mine near the firewall drivers side. I did buy a new one with the intention of changing it, but after a few taps with the plastic handle of a screwdriver, it released and has not stuck again. Maybe you car has one. Photo below.
G
garyj144
Thank you John..will check that out. Much appreciated.
G
garyj144
I have but still would cook a chicken :). Thanks for helping. Appreciate it.
