charlysays
- Jan 11, 2016
- Location
- Pembrokeshire
- Mercedes C250 Turbodiesel Sport Auto Estate
My W202 has just gone over 200,000 miles. As such I thought it was high time I changed the PSF as this is the only serviceable thing I haven't done (I've even dismantled and repacked the front hub grease). The steering box also isn't worn out surprisingly despite the mileage, steering still feels precise even at high speed so I'm keen to keep it that way for as long as possible.
I think I've found the correct fluid - Febi 08972. Mercedessource on youtube has warned against using ATF as he has found it causes increased wear in the steering box due to lack of the correct additivies.
Can anyone please describe the best procedure for changing it?
Sucking as much old fluid from the reservoir as possible, topping up with new fluid then starting the engine briefly with the return line disconnected and in a bucket seems like a good idea but I'm worried about running the system dry if only for a few seconds. Or should I just do the lazy way and use a turkey baster to do repeated partial changes at the reservoir?
Thanks in advance
Thanks in advance
