And probably a bit less due to the SLK not being as heavy?
I set the pressures at manufacture recomendation. The ride was so hard it felt like I was back in my MG TF!
Think I'll set mine at 26 front and 28 rear as oppossed to 30 and 33
That's not the brightest idea to be fair, if you under inflate the tyres by 6psi you are in danger of a blowout, the tyre gets hotter and the sidewall can burst.
This is an extreme, but not worth risking.
Also, I had a chart somwhere that BMW supplied for the E46, going from a 15" 195/65 profile tyre, up to the 19" 265/30 profile, and the differences in pressure was quite extreme, 31psi for the 15" and 42psi for the 19" on the rears.
I would never run anything below 29psi, at 25psi I would be worried driving it.
Tyre pressure remain the same irrespective of the wheel/tyre combo.
Really? On 911's the pressure can hange quite dramatically between even 16" and 17" wheels, albeit more so on the older models. Once you are into 18"/192 they become the same but the variations are definitely there and significant.
