How do I get a t front speakers in W124 ?
Jason Tillyard
I have a 94 280E estate. One of the front loudspeakers in the dashboard is playing up, cutting in and out - sounds like a loose connector. Simple question is - how do I get at it ? From above (remove speaker cover ???) From below ? (it's driver's side)
Any help appreciated !!
Jason
bundy
merseyside
hi jason
if you remove the plastic edge trim from the grille then remove the grille you can then remove the speaker from above. its a bit awkward though ;-)
Bolide
www.w124.co.uk
BMW 525 Diesel Touring
Intermittent speakers
Intermittent speakers normally means broken tinsel leads to the speaker & a new speaker required
You can get them from a dealer or get an aftermarket part from MAC Audio and a couple of other manufacturers. They're a non-standard size (120 mm) so a dealer may be your best bet
Nick Froome
www.w124.co.uk
Jason Tillyard
Sorted Now - thanks for the advice !
All sorted out - appreciate the advice, thank you.
