OK, pop off the plastic door release cover, and you will see a 10mm bolt undo this bolt and slide out the door release towards the front of the car and disconnect it from the cable.
Next step is to unscrew and remove the small black plastic cover near the door slam and also the triangle shaped bit near the mirror.
Once these are removed the whole panel can be removed by lifting it in an upwards direction - do not try to 'pop' it out sideways like on most cars. This can be a little sticky and you will usually find that the bit around the top strip near the window rubber is where it is catching. I found the best method is to wiggle it in an upwards direction and it will work itself free pretty quick.
GAD was founded in 2009 where we developed bespoke ECU Remapping software for motorsport clients, moving forward, we have extended to road vehicles for both performance and economy, contact GAD Tuninghttp://www.GADTuning.co.ukto discuss your requirements.
