How do I repair W124 retracting headrests?
Waft
Cambridgeshire
1993 E220 Sportline Coupe
Hi!
The rear reatracting headrests in my 93 E220 Coupe have stopped working on the button now.
I know the system works using the vacuum system.
How do I address this problem though?
I'm fine pulling things about to get to the source of the problem.
TIA
Steve:)
grober
Scotland
W204 C200cdi estate
try this http://www.benzworld.org/forums/w12...diy-removal-rear-headrest-w124-pneumatic.html
You can access the mechanism from the boot. Basically the head rests are raised manually and released[ lowered] by vacuum. There's a vacuum solenoid valve under the rear nearside seat I think which is opened by the switch on the dash to allow vacuum to the head rests - its possible this has failed [ water damage sometimes]
I do have the retro fit instructions and that cover it all :D:D
Waft
Waft
Cambridgeshire
First job of the week on her then!
Thanks guys!
:D
If you need the paper just pm email
BlueTiles
New Registration
W124/1993/M104
Hi, the rear headrest in my e320 1993 suddenly cannot be dropped anymore from the front panel button. It used to work before. Any suggestion where I should start to check this?
