How do I see remaining fuel amount and how many miles I can drive before empty ?
Sr108
E class
Can’t figure out how to get this info on the speedo ??
Press the info button top left of the steering wheel then scroll through the menus. It will show an estimate of mile remaining although that very much depends upon throttle and brake usage. Once it thinks it needs filling up it switches to a picture of the car with a fuel pump.
It helps if you be a bit more descriptive on which E-Class you have as they been making them for nearly 30 years and the dash info and how you access it has changed quite a bit in the intervening years…
Sr108
E class
Oh yeah stupid me forgot to say what car it is , 2012 e350 cdi . I have managed already to get it on this screen so is that it ?
Yes, you need some motion lotion…;)
Sr108
E class
Gonna go now and get some , when I start car it changes and just has this ..
It’s reminding you… once you fill up that display will go
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
Once it can't work out how far you can go is a good time to buy fuel.
w204benz
2012 C200CDI AMG Sport
I have seen the remaining range display go up as well as down while driving, so I would only use it as a rough indication of the fuel level.
However, there is a hidden menu that shows you how many gallons (or litres) are in the tank. It does require programming through the OBD2 port, but it's relatively simple if you have the tools (or know someone who does):
I've also noticed the analogue gauge lines up quite well with the display, it's somewhat useful if you know the tank capacity. I wouldn't be surprised if it was computer controlled rather than truly analogue.
The manual should also mention the fuel level at which the reserve fuel warning comes on - might be worth looking it up.
EmilysDad
Bury Lancs
ML350
I have seen the remaining range display go up as well as down while driving, ...
Of course it can rise. eg you set off in the morning when it's cold with 10 galls in the tank, your car is still on 'choke' & doing 25mpg .... 250 miles left in the tank. The engine gets warm, comes off 'choke' & is now doing 35 mpg because you're doing a steady sensible speed on the motorway .... there is now 350 miles left in the tank (apart from the miles it took to get warm)
ajlsl600
france
Take a note of speedo when reserve light comes on. When u come to halt that was reserve to empty.!! Take note of miles indicated Best avoided.
Larkone
NW Essex
C219 CLS 320CDI 2008
Didn't we invent fuel gauges at some point?
  • Like
Reactions: DSK
