How do I take this out?
dpmstevens
A180CDI 2006
Hi all,
I need to replace the fuse box in our W169 A180CDi, as it's corroded after the cabin got wet. But I can't figure out how to remove the wiring from the car to the fuse box. Each cable is locked into place but there's no obvious way to remove them.
Anyone know if there's a special tool or a trick to this? I guess it must be possible to do...
Cheers
Dan
Hi all,
Cheers
Dan
Let’s have a picture buddy
D
dpmstevens
A180CDI 2006
Here you go. Pic of the underside of the fuse block, with the wire entering. One of the top of the fuse block, where the fuse plugs in. And one of the connector on the wire, which I removed from a spare fuse block by cutting it open.
The connector has a silver V-shaped tab that locks it into the block. I need to know how to release this.
Cheers
Dan
Snake Charmer
S211 E320 CDI 2004
That last photo showing a two part crimp terminal, the stainless steel part appears to have a dual purpose as spring and retainer.
Firstly, retainer barbs to keep the crimp within its housing at correct height and alignment.
Secondly, the brass crimp fuse contacts become sprung to contact the fuse when inserted or removed acting as a wiper with additional contact in the bottom of the crimp vee.
There will be a correct tool for removal, is there an additional barb on the opposite side of the stainless part?
D
dpmstevens
A180CDI 2006
That's a great explanation - thanks. Don't think there's another barb on the stainless part. I might remove another one to check as this could have been damaged in the removal process.
If there is a tool, I need to find it or make something similar. I've pushed pieces of wire and cut down tweezers through the top of the fuse block, but they don't work.
EDIT: there's a barb missing from the stainless part. Must have broken off during removal. It should look like this:
Those connectors are kind of single fit - they’re not really made to be removed.
I’ve used very thin screwdrivers to take multiple plugs apart previously. With care you can get the barb released - sometimes it’s better to press the connector further in initially so the tension is off the end of the barb, then slide the screwdriver in bend the Barb so you can slide it out.
peterws1957
Lancashire
This exactly, a small thin screwdriver does the job every time.
D
dpmstevens
A180CDI 2006
I've been trying screwdrivers but with no luck. Can't find any tools specific to these terminals - those 83-piece sets you get on eBay and Amazon reportedly don't contain the right tool...
NJS5
Catherington, Hampshire.
2011 R230 SL350, 2016 Discovery 4 Landmark, 1973 MG B GT V8, 1959 MGA roadster.
Hopefully Dreamer No2 will be along shortly with a link.:)
D
dpmstevens
A180CDI 2006
