How do you go about changing the PAS fluid and filter on a W202?
chizzel89
Pembrokeshire
Mercedes-Benz C250 Turbodiesel Sport Auto. Estate. 1998. 180,000 mls
I bought a new PAS filter from GSF on a whim, and I feel like fitting it sometime. However, the paynes manual doesn't cover replacing this filter and I can't see how it can fit into the PAS pump- it's too big.
Anyone done this or am I mental for bothering to change the PAS fluid? I just have an idea that fresh fluid might reduce wear in the pump and also the steering box?
yorkshire1
East Yorks
"98 S202 C250TD Manual hybrid
filter
I know older mercs with metal reservoirs had filters in but Im not so sure the plastic later reservoirs had one
I will look it up as soon as I can
grober
Scotland
W204 C200cdi estate
If its the old metal type then the central plastic level unit unscrews to reveal the filter underneath. Many folks suggest simply syphoning out the majority of the fluid in the reservoir with a turkey baster or similar renew the filter and then top up as necessary. Run for a few minutes and then drain and repeat the top up. That way the majority of fluid is changed/flushed without disturbing the pipework.
