How do you remove the Rear luggage cover motor completely?
John77
E200 Estate 2011, 2016 Smart Car
How do you remove the Rear luggage cover motor complete with the Springs/cables, whatever they are called. This includes removing the side Trims that hold the plastic runs for the springs/cables? See photo.
V6Matty
Newark, Nottinghamshire
The motor is actually located in the head lining, afraid it’s a pita to remove and replace but once the headliner is down (yep loads of trim to remove) it’s a few screws and that’s it.
John77
Yes I can see the motor. I wanted to know how to remove the side trims so I can take it all out.
V6Matty
Lots of screws in the boot floor and then start at the bottom and work your way up, few more screws in the side trim but mainly clips from there on out if I remember correctly, though it was about 4/5 years ago I did it so the memory might be a little fuzzy
John77
Thanks for that I will take a look and see how it goes.
