IAN MAC said:Should be easy indeed, its the same engine as they put in the Sprinter van and just look at the mileage on some of those that are for sale.
c250 turbo diesel said:Sprint &go, did you get your 270 repaired under warrenty ? if no what cost to rebuild ?
I will explain more the first things to go on the 270cdi.
1... heater plugs x5, and if you run with even one gone you'll need a relay to !
2.. injectors best change 5, and high pressure fuel pump, i am told the newer one are better ?
3 various/mumerous fault codes, check the price of the above work at a merc dealers, don't take to cowboys !
The older 2.9 engine you could put your hand on you heart and say big mileage small costs, with the 270 that indeed goes well, you can be sure big mileage = big pay outs !
Don't compare the 270 with the older 6 pot lump from the e series, different as chalk and cheese.
And don't listen to the computer chair wizzards who up and up the hundreds and thousands of mile they will supposidly do !
Half of them dont even own one, and are talking pure cr-p !
A user now of several, and talking from experience !
It needs reviving!I wonder if the OP's E270 is still running?
