How many watts?
PROJUMPER
Mercedes
Does anyone know the wattage of the indicator lamp in the wing mirror on a ML 164 series?
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
Not sure about the ML, but most MB mirror indicators are a LED strip.
P
PROJUMPER
Mercedes
I believe these are a strip, I am trying to determine the wattage of the complete strip.
M80
Derbyshire
I have one removed from my Viano behind me,
it is 4 LED's that illuminate, 2 through 2 reflective plastic runs across the front of the mirror, and also 2 out to the side.
At a constant 14 volts it runs at 133mA.
If that's any use for your purposes??
jimbg
E Class Estate 2020 220d Prem Plus
Less than 2 watts then!
P
PROJUMPER
Mercedes
Thank you, exactly the information I am looking for!
My wing mirror LED's have corroded and the dash information light is on stating the bulb has gone, so if I put a resistor to replace the LED lights the dash lights will not come on....
So what I need to know is what size resistor do i need to replace 133mA?
P
PROJUMPER
Mercedes
There is no legal requirement for a particular wattage for side indicator bulbs so you are at liberty to put in anything.
https://www.legislation.gov.uk/uksi/1989/1796/schedule/7/made
Thank You for the reply, the MOT guy told me the exact same thing, what I am trying to do is, switch the dash information light off, which telling me the bulb has gone!
My thoughts was to put a small resistor in the wiring to replace the LED's.
sonic
Staffordshire
All lights fitted must work, so to be legal you will have to remove the LED strip.
M80
Derbyshire
Without a mirror repeater you would need a wing repeater for the MOT.
That's for Vito / Viano at least and I don't see why an ML would be different.
I replaced the LED on the Viano for less than £28.
jimbg
V = I × R
where:
V is the potential difference in volts, V
I is the current in amperes (amps), A
R is the resistance in ohms, Ω
The equation can be rearranged to find the resistance:
R = V ÷ I
EmilysDad
Bury Lancs
ML350
Is this the same led repeater as fitted to the preface lift R Class? They look similar/same o_O If so, I have a driver's side mirror indicator sat in my garage doing nothing .... you can have it FOC :)
P
PROJUMPER
Mercedes
Wow, I believe it is the same one, thats a very kind gesture, please let me know the P&P costs, is there anyway that I can private message you?
sonic
Staffordshire
V = I × R
where:
R = V ÷ I
I can remember doing that at Tech College 55 years ago.
