could be very good as number 33 looks like a hiden bolt, I even pulled the flap off inside the car but that just gained access to the back of the fuel filler. Looking at that picture there IS a bolt hidden up there..
Is that a web site full of exploded views? or have you a sort of haynes manual on disk?
After removing the aforementioned (plastic) bolts....pull the lamp unit 'sharply' rearwards.........the 'hidden' fastenings you refer to are a type of recessed spring clip and the sharp tug will release the unit from these.
