How to replace mirror glass on w203
paul c
Have just got my car w203 out of my garage and discovered a hairline crack in the driver door mirror glass does anyone know if this is easy to replace or is it a garage job if so any idea of cost.:(
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Rough guess the glass will be about £60, easy enough to do, there is a small stainless steel clip inside the mirror, if the mirror is in the folded postion its just visible but its probably easier to remove the complete mirror off the car, the cover slides off and the mirror has a spring clip with two wires behind it.
job should take 10 mins tops.
jib
P
paul c
Thanks for the advice how easy is it to take the mirror right off i can see three screws and the clip when they are folded back are those screws all there is to it?:)
P
paul c
Thanks to you both will price one up and decide.
