Unit504
HOWTO: CLK 230 Convertible - topping up the hydraulic fluid - w208
think this post maybe better in the how too not sure tho!
following carried out on a 1998 clk230 convertible
first you need to open the roof and stop it in the position so the bow of the car is open along with the window part of the roof:
then remove all the carpet clips holding in the carpet:
clip:
over view:
once removed all the clip you can then take out the top part of the carpet:
after that roll back and remove the roller boot closure (this is only held in with one bolt either side of it)
as you need to get to the bolts behind it.
bolts behind boot cover:
clip:
over view:
