Parrot of Doom
- Nov 14, 2005
- Location
- Manchester
- Was an E300TD, now a Lexus LS400
Right, as I'm having problems with my aircon (blowing intermittently hot on driver's side) I thought I'd check out the duovalve to see if it was working correctly.
Feel free to point out any stupid errors I've made, but this is what I did:
1) The duovalve from what I understand controls the flow of coolant to the cabin. Obviously you have separate passenger/driver heat controls, so thats why you have 2 valves. On the W210, its located near the brake fluid vessel, offside at the back of the engine bay:
See the two grey cylinders? Thats the duovalve.
2) Start by making sure the coolant isn't too hot. The last thing you want is to open it up and roasting hot coolant comes shooting up your arm, forcing a trip to hospital for burns! First, unplug the power connector. Its a bit stiff, so you may have a bit of a struggle removing it. Its clamped on either side, I used my fingernails to pull the plastic clamps back so the plug could slide free.
3) When its reasonably cool, take a torx bit and unscrew the 5 torx bolts that hold the metal case together:
Don't worry about losing the bolts in the engine bay. They're very long, the reason will be evident shortly:
4) Once the bolts have been removed, you can remove the two covers. They just slide off very easily:
You can now see 2 orange cylinders, not unlike cotton bobs. These are electrical coils, and they're what makes the pistons in the valve move in and out (its the same principle as a hifi speaker). I presume the position of the valve is controlled directly by the position of the temperature dial in the cabin. The two blue components are capacitors, very very cheap and easy to replace. Nothing exotic.
