hydraulic fluid???
needs a wash
west norfolk
Hello all
I’m the proud owner of a 1983 230TE
A couple of flaws but v.sound
The first car I have ever enjoyed driving slowly.:)
There is a reservoir marked :confused this is now on the low level marker.
By process of elimination I assume this is for power steering could some one confirm this and recommend the correct product to top up with.
Much appreciated
jim
Hello all
Much appreciated
jim
Is this on the power steering pump driven by the fan belt.
Malcolm
Hibbo
East Scotchland
It will probably be for the rear self-levelling suspension. The PS reservoir is part of the pump and can't be viewed without taking the top off
eric242340
Banned
China
I beleieve Hibbo is correct here, but could you post a picture to clarify. If you put the wrong fluid in the self leveling suspension, it would cause you a headache. Thanks.
HeHehe,I hope he took the top off :D :D :D :D
malcolm
Hibbo
East Scotchland
As an aside, should the SLS hyd fluid be changed as a service item? Or is it a ballache to do, and should be left till the spheres are done?
My w124 estate is just aboot to turn 170k and is on its original spheres, going to give it a full service soon.
eric242340
Banned
China
I think a bitch of a job comes to mind, better to top up the system , when required, until the pressure bowls (spheres) fail. And when one does, do a system overall and change both plus the fluid. When this system is working ok, its far better to leave well enough alone.;) Please trust me on this one:shock:
N
needs a wash
west norfolk
typo
in my original message it should have read,
"There is a reservoir marked hydraulic fluid, this is now on the low level marker."
not
"There is a reservoir marked: confused this is now on the low level marker."
sorry for the confusion. a smilie back fired.
jim
ps the reservoir is to the left of the engine
i'll send an image when my wife brings it back from work =-)
looks like I am winning on this one :D :D :D :D :D :D
malcolm
N
needs a wash
west norfolk
here is said reservoir marked hydraulic fluid
did i say the car is an automatic?
is this for SlS or sumit else?
thanks jim
N
needs a wash
west norfolk
thanks jim
Hibbo
East Scotchland
I'm 99% certain that that is for your SLS.
The car being an auto is irrelevant; there is no reservoir for the autobox, all the fluid is contained in the box itself.
Look up your car at www.detali.ru and look up the SLS, it should show the location of the reservoir.
Got to be SLS :)
Got to be SLS :)
Looks like you are winning on this one Hibbo :D :D :D :D :D
Malcolm
N
needs a wash
west norfolk
  • #17
thanks for the help
ok so it 99% SLS, cool i'll go with that.
next question what should i top it up with?
thanks again :)
jim
I have a horrible feeling that the power steering shares the same tank.
this is a 123.
Malcolm
