I have a 1999 mercedes ML 320 I've been stranded because of the immobilizer and my wife cant walk. can someone tell me how to bypass the immobilizer
jimmy@57
New Registration
can anyone tell me how to bypass the engine immobilizer for a 1999 ML 320
Hello and welcome
errr no... because we’ve no idea if it’s your car or just one you fancy...
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
There is no simple way of bypassing the immobiliser on a ML, it is an inert programmed chip in the key fob that releases the immobiliser when in close proximity to the ignition switch.
Can I ask what makes you think the issue is with the immobiliser as opposed to anything else?
mioba
Nottingham and Köln
Get your car recovered to a MB dealer. Welcome to forum and do stick around :p
Hi and welcome. What are your symptoms?
If it won't turn over it could be immobiliser, starter or starter solenoid.
If it turns over but won't fire it could be injection pump, crank sensor.
Crank sensor failure is fairly common on these engines but not expensive or difficult to fix.
Taffy7hfa
Oxford
If your alarm system is going haywire and not allowing the car to start it maybe because the alarm siren module is shot, there are batteries inside which degrade over time and destroy the pcb, this can cause all sorts of issues including sometimes stopping the car from starting/ Start error message etc.. it lives below the windscreen wiper motor ( below the scuttle) its a very common problem on many older Mercedes.
