I have a Mercedes C 200 KOMPRESSOR 1.8 2009
yasser
New Registration
c200 kompressor 1.8
I HAVE A MERCEDES C200 1.8 KOMPRESSOR, WHEN I PUT P SHE CUT THE THROTTLE AND WHEN I TURN P THE POWER TURN OF THE ENGINE. NEED HELP. I CHANGE THROTTLE BODY AND KOMPRESSOR COMPLETE. SEAN PROBLEM. I CHECK SCANNER ONLY DTC CAN TRANSMISSIN TO PCM, ABS. ANY BODY TAKE SEAN PROBLEM ?
ernieh
Scotland, East
Your best plan would be to have the fault codes read with STAR. If you post where you are, someone on here may be able to point you to an MB Independent near you. Otherwise, guessing may cost you money unnecessarily.
Having said that, your fault, if I understand it correctly, could be due to an air leak. I understand that some of the small vacuum pipes below the air cleaner box can perish and leak. Someone else may have more specific experience that may help you.
Ernie
Tel: 020 8863 9233
