I is fick.... postcode search on Comand 2.0?
Peter De La Mare
15 reg E63, 14 reg Smart Passion and 64reg Caterham Levante.
Ok, I have the lastest 2007 CD with TMC enabled, but I must be missing something as I can't figure out how to do the postcode search.:confused:
Had a quick delve into the manual .PDF but didn't see anything obvious.
Unless of course, it's not available on the Comand 2.0 for the 2001 W210. Which wouldn't surprise me in the slightest. :-(
mr. serious
Cant you just make a quick call to your local stealer and ask them? Someone in their 'technical department' must know...? Just a suggestion...:smile:
Alfie
Surrey/Cotswolds
www.comand.co.uk
Provided you have the latest firmware update then postcode entry works fine with your disk on Comand 2.
Simply enter the postcode you wish to go to using the letters and numbers. If it does not work, then you need the MY01 update applied to your comand which can be done easily either by downloading the image from the internet and burning it to a Cd or buying the correct Cd from your local dealer.
Peter De La Mare
Peter De La Mare
Ah, my faith is restored. I was getting worried. :eek:
Thanks Alfie, much appreciated. ;)
