I know it's probably a bit late in the day, but
100%Bitch
Norfolk 'n' good
What exactly is ABC?
And I don't mean the alphabet!
Active body control sweet lady, you may have noticed that when cornering hard the car exhibits virtually no roll or pitching when you brake.
100%Bitch
100%Bitch
Norfolk 'n' good
How does that work then?
100%Bitch
100%Bitch
Norfolk 'n' good
You apply pressure on the large left pedal and the brakes are applied through the SBS
There's always one. Can't you be serious when answering a thread or are you a Muppet?
Oh God, that reminds me of somebody.
No seriously, how does ABC work?
An active system measures the car height, and the suspension is hydraulic, this keeps the car level under all circumstances, if you brake, a normal car dips at the front, not with ABC, as you brake the front suspension struts are pumped up to keep the car level, if you go round a bend a normal car rolls, not with ABC as the side that would normally tip is pumped up to keep it flat or level, thats what make the 230 so comfortable.
I do have a technical link that I can post, but it is very technical
100%Bitch
100%Bitch
Norfolk 'n' good
Yes please.
colechelle
Resigned
"muppet" that's a bit "Da Ja Vue"
wheres roofless??????? ABC monitors the amount of force put on to any one of the struts at any one time and compensates for that amount, hence making one strut firmer and others less, i think from training it does all that in 0.9ms (milley seconds) faster than you could lose the car, then if you still in trouble the esp will take over and take the throttle away and sort you out before you know it!
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
Everyones description of ABC is what I thought ADS was, what is ADS?
PeterCLK
Cumbria
2012 204 Elegance saloon 220 cdi
Airway
Breathing
Circulation
Can I be the first to volunteer to give you CPR if you ever Conk Out"?
