RhodieBill
- Jan 30, 2019
- 2001 W208 CLK320 182U ALMANDINE-BLACK METALLIC
After doing a quick oil and filters, Oil/Air/Pollen. I gave the car a good clean including the Mats etc.
Whilst doing this I was constantly opening and closing doors when suddenly I noticed the Soft-close stopped working - and the Boot wouldn't open other than with the Key. Not to mention the Central Locking and Rear Headrest Drop-down being inoperative! (Been perfectly fine before and nice and quick)!
Anyway, sussed that Fuse "62" had blown - big deal, fuses blow sometimes.
So to cut a long story short I ended up blowing £ Fuses eventually. (All the 20amp Fuses I had except one).
The only other thing I noticed is that when I removed the Driver's Mat I banged a little white Tube under the Seat, but it still looks all connected to a connection in the Frame joining a similar black Pipe. No damage is obvious.
Anyway, I got fed up and have left it with the Fuse "62" removed, (last one I have) and locked it up with the Key but armed the Alarm with the Fob. (Lights flashed 3 times).
Have I basically $*&"*^ up the Pump or is it something else.
To be honest I'm starting to feel I should have kept a perfectly good CLK320 instead of buying this heap!!!
Said Fuses!
Said Fuses!
