I think Ive got a problem
montyzappa
bishopstoke nr eastleigh in hampshire
Auto gearbox problem
When cold my 2L 190e auto drops down into first gear at low speed and somtimes when pulling away . It has only just started doing this . does this sound unusual ? Could it just need a fluid change ?the gearbox feels as if it can,t decide which gear to be in .
Keith
Parrot of Doom
Manchester
Check the level first. You don't want to overfill, you may cause more problems.
C220GJS
Shotts, Scotland.
1995 W202 C220 Elegance
Dexron-111 should be ok for your box, originally filled with Dexron-11, but as you say you don't know what's in there now. I wait to be shot down by purists but i would say that any good quality ATF to Dexron-111 should be suitable and not a problem to mix brands.
Recommended to change ATF and filter on this box every 30,000mls or 15,000mls under severe driving conditions. Cheers Geo.
