I want lights to extinguish when tailgate is closed.
M80
Derbyshire
Viano 639, 2014.
The rear wiper doesn't work when the tailgate is up.
So the SAM recognises it being closed.
That though is 'likely' to be a canbus signal, from within the lock mechanism is my guess.
But can anyone suggest a way to pick up a changing state terminal that I could use for a relay perhaps?
supernoodle
E220 2005 2.1D
CAN is just a means of communication. Even if there a CAN signal for open/closed status there would have to a physical hardwired signal read by a module for that to be possible.
Is there a switch in the lock mechanism? If so I would expect it's make/break set up. You should be able to suss it out with a multimeter.
M80
M80
Derbyshire
In the sliding doors there is a micro switch that recognises the door as closed.
I'm assuming the same for the tailgate.
My thinking is that to try and utilize that for such as a relay might confuse the 'calibration' of the signal to the SAM, via the canbus??
